跳转到主内容
加入维修社区 - 创建账户
适用于 2020 年 4 月发布及推出的第二代 iPhone SE 的维修和拆解信息。
iPhone se 2020 problem touch id
iPhone SE 2020. Home button works normally, but Touch ID does not respond at all when adding a fingerprint. No error message appears. The phone was opened previously for network repair. Hidden Apps are asking for Touch ID and never fall back to passcode. Has anyone seen this before?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If the Home button still clicks and functions normally but Touch ID doesn't detect your finger at all, that usually points to a communication issue with the Touch ID sensor rather than the button itself.
Since the phone was previously opened for a network repair, it's worth checking the Home button flex cable and connector for damage or poor contact. A board-level issue is also possible if the repair affected the Touch ID data lines.
I'd also check for any panic logs and run an iPhone panic log analysis. While Touch ID issues don't always generate panic logs, they can sometimes reveal hardware communication errors that help narrow down the cause.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DJAMAL YACINE 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 35
总计 135
