跳转到主内容
加入维修社区 - 创建账户
针对 MacBook Pro 13"(配备第二代 Apple Silicon (M2 芯片) 和 13.3 英寸视网膜显示屏)的维修指南和说明。型号 A2338。于 2022 年 7 月 15 日在 WWDC 2022 大会上与 MacBook Air M2 同时发布。
My touchbar stopped working
my 2022 m2 13 inch macbook pro touchbar lights up but doesnt respond. all keys work, esc and touch id work, only thing is touchbar not responding but responding to screen (safari, imessage, etc)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Did you get it wet? Trying to clean it or something.
完成的
i didnt get it wet, it also isnt dirty. it hasnt work for a year
完成的
添加一条评论
1个答案
Sadly, the issue is likely a damaged display from a bang. The easiest way is to replace the upper case assembly, but that's quite costly while it's possible to find the TouchBar part it's a bear to take off the broken one to replace. This part is starting to become hard to find. The last option is to try to locate a junker which still has a good uppercase to swap-out or just live without the it using an external keyboard to gain access to the inputs it offered.
Here's the full repair manual with the needed parts info 2022 13" MacBook Pro service guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ethan Luessow 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 26
总计 172
