How I can replace transmission oil
How I can check transmission oil level
@mandeepmaan here are the Atfinstructions for the Ford PowerShift DPS6/6DCT250 which is one of the transmissions used in your Fiesta. Essentially, you open the drain plug to drain the ATF (on a warm transmission only) and use the filler plug to add ATF. You will need to fill until it starts to leak back out of the filler plug.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 63
总计 63
@mandeepmaan what exact year and model is your Fiesta and I assume you are referring to an Automatic Transmission?
由 oldturkey03 完成的
