Why wont my laptop load the main screen
when i turn my Acer Laptop model number pav70 on all it does is load and reload a blue screen it will not go to the home page or anything
Tabetha, I am assuming you are talking about the windows home screen. Try to start your Windows computer into safe mode "To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu." Hope this helps, good luck.
这个答案有帮助吗?
I agree with oldturkey03. It also sounds like it could be the "Blue Screen of Death" or BSOD that many laptops get when there is something wrong. If this is the case, you would not be able to boot in to Safe Mode. Every BSOD gives an error message number which then has to be looked up to determine the exact issue. If you happen to know what the error message is, One of us could let you know more specifically what is wrong with your computer. It could be the hard drive failed or even that the Windows OS just got corrupted.
这个答案有帮助吗?
I clicked safe mode and it went to a black screen with safe mode in all corners. What do I do now?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 12
总计 32,036
6条评论
I can't get to the start up menu screen to enter password it just keeps skipping the password screen over and over
由 Ricky Soto 完成的
It won't go to password screen
由 Ricky Soto 完成的
Same problem dude! Why is dis happening to me?
由 Jimmy da savage kid 完成的
Where man i go to get my Labtop Fixed
由 cdejackson 完成的
I have same problemm
显示更多的1条评论
