跳转到主内容
加入维修社区 - 创建账户
由 Numatic 制造的 Henry 真空吸尘器。
Power cut and not working
Not working. Power cut
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Like @rodolfomeave, I'm not familiar with your particular vacuum, but I had the same issue with a Harbor Freight shop vac.
By testing the power going to the fan motor, I finally isolated it to a failed thermal fuse on one of the motor leads. These are designed to blow when the temperature exceeds a particular limit, but I have no reason to think mine was anywhere near that range when it blew. Anyway, replacing the fuse got the vacuum up and running again and I haven't had an issue with it since. Here's the part I purchased; yours will probably look similar, although you'll need to use the markings on it to determine what value to use for a replacement.
10pcs 10A 250V TF thermal protection Rice cooker fuse RY-65 75 80 100 120 175 185 210 230 280 Metal shell Temperature Fuse - AliExpress 502
Good luck, and be sure to come back and let us know what you find!
这个答案有帮助吗?
得分 2
添加一条评论
I do not have a Henry Vacuum, but if you are still having power issues there are some troubleshooting checks that you can do:
  • Make sure power cord is fully connected to power outlet
    • If outlet is a GFCI, also known as GFI, outlet; Make sure the breaker is not disconnected
  • Inspect power cord for any hard kinks, cuts, or anything that could potentially have broken the copper wire inside
  • Inspect for broken or loose power switch
  • Inspect internal wiring and PCB for broken connection, burnt components
Hopefully this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 199
