跳转到主内容
加入维修社区 - 创建账户
Loose USB-C charge receptacles
Both USB-C side-by-side charging ports will charge laptop only if wiggled, and no power light next to ports. Need part number, and whether this is a pluggable part, or requires soldering. Thank you! A part picture would be handy.
Found that even though connector seemed fully inserted, it was not. Cleaned receptacle with narrow, stiff brush, and contact cleaner several times ...it is now charging again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@m7vtuqoqzqrwbhl those ports are commonly soldered to the motherboard. WE will need to know your exact computer model as well as what motherboard it has. That way we can most likely find replacement ports. It may also be possible to just resolder the ones on your board. wE will have to see all of that to be certain. Post some well focused pictures with your question so we can see what you see.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
C H 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 30
过去 30 天: 30
总计 30
