跳转到主内容
加入维修社区 - 创建账户
Renault Clio 汽车的第二代车型。于 1998 年发布。
Computer box not recieving 12v
My clio 2 has lost power on coil connectors now it doesnt start its just quite
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
Hi @bonganisib42530
Does the engine crank when you turn on the ignition key?
Have you checked that the battery is OK?
由完成的 分享
It used to crank before i thought its the crank sensor but only to find out after diagnosing it had a code that reads +after relay supply
由完成的 分享
@bonganisib42530
Did you check if relay #1 Ignition main circuits relay 1 in the instrument panel fuse box is operating (click sound) when the ignition key is turned to start.
Also check relays #5 Starter motor relay, #9 Ignition main circuits relay 2, fuses F13, F14, F18, F22 & F24 in the engine bay fuse box are all OK.
All the above need to be OK when cranking and having the engine turn on
由完成的 分享
I dont know which relay is the ignition relay there are 3 of the brown ones 20A then there are 2 pink 40A then purple 50A but all the fuses are ok i once tested a bridge that i think is the ignition relay and it blew the ignition fuse thats maybe when i started realizing that it may be the ignition relay
由完成的 分享
@bonganisib42530
Here's a link to the fuse box diagrams for the 2006-2012 Clio models (you didn't say which year your vehicle is) that shows the location of the relays and fuses in the 3 fuse boxes i.e. main fuses box and power supply box in engine compartment and fuse box in instrument panel in the passenger compartment.
由完成的 分享
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
Hi @bonganisib42530
Here are the wiring diagrams for a Clio II, that might help. Hopefully they are applicable to your model
这个答案有帮助吗?
得分 0
1条评论:
Thanks i see the diagrams
由完成的 分享
添加一条评论
添加你的答案
bongani sibanyoni 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 39
总计 209
