跳转到主内容
加入维修社区 - 创建账户
A2115 / 2020 / 处理器包括 3.1 GHz 6 核 i5,最高至 3.8 GHz 8 核 i7。发布日期:2020 年 8 月 4 日。
SDD ribbon cable replacement
I have a bare 820-01779-A logic board and am trying to identify a small ribbon cable connector on the screen-facing side of the board. There are no SATA connectors on the heatsink side as seen on 2019 boards. Can anyone identify what this ribbon connector is and whether it has any relation to SATA storage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The 2020 model dropped the SATA port and even the Blade SSD! This series has soldered on Flash chips on the logic board on the base models and only on the high end give you access to more SSD storage via a custom flash (NAND) module. I haven seen this model personally, I suspect it's the same as the iMac Pro 27" 2020 iMac specs
Bottom line you can't upgrade or expand this systems storage internally.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pdstreeter@hotmail.co.uk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 70
