跳转到主内容
加入维修社区 - 创建账户
第四代雪佛兰 Caprice 的维修指南和支持信息。这是一款前置引擎、后轮驱动的全尺寸轿车。它与 Impala SS 和别克 Roadmaster 等其他通用汽车 B 平台车型密切相关。
Car cut off while driving
Car drive but cut off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is the car shutting off when the gas is pressed, or when coming to a stop? What year model is it?
由完成的
添加一条评论
1个答案
First step is too determine if the problem is fuel related or ignition. Start with a code scan and solve any engine related codes. If that doesn't fix it then when the engine dies, check for spark, if you have no spark fix that problem. It could be the module, the reluctor, the cap or rotor, the ignition coil, ignition wires even the spark plugs.
If the engine has spark when it dies, put a fuel pressure gauge on the engine. If the engine quits and has no fuel pressure then the problem is the fuel system. It could be the ECM, wiring, relay, fuse or the pump.
Obviously this diagnosis if not for the faint of heart nor the uninitiated. Your best bet may be a mobile mechanic. The car is rather old so an older mechanic may be more familiar with your cars systems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 26
总计 137
