跳转到主内容
Second generation of the Ford Focus.
How do you change the fuel filter in a 2007 Ford Focus?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
were is the fuel filter on usa ford focus 2007. how do I best change this filter
完成的
hi there
i have a 2007 ford focus 1.6 si hatch back and my fuel filter is attached on the the frame of'
of the back axle. i have seen pics of other cars location and i cant understand why my car is different.
完成的
添加一条评论
1个答案
最有帮助的答案
James, there are great write ups with images on here and another very good one right here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
3条评论:
Hi Thank you but my ford is a european focus which seems to have a different filter, do you know of anywhere for these?
Kind Regards
完成的
James, here is one for the UK model "it is in a recessed area just ahead of the fuel tank - visible on the passenger side just ahead of the rear wheel. You have to release the fuel pressure with a special hose clamp release tool before removing the hoses. Then there's one small clamp bolt that holds the filter itself.
完成的
i am confused now because my fuel filter is attached to the back axle frame and it
does not look like the one in the pics.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 10,654
