跳转到主内容
加入维修社区 - 创建账户
Keyboard Key Dectection Inconsistency
I've been having a reoccurring problem where certain keys on my keyboard don't get detected when pressed, usually my entire 3EDC column and H key although other keys are sometimes affected. They usually stop working after a period of inactivity and most of the time I can get them to work again by repeatedly pressing the affected key. I am running Debian based Linux as my main OS but I do also experience this problem in Windows 11.
I'm just putting this out to see if anyone else was having this experience or knew of any fixes.
Lenovo yoga 7 2in1 14AHP9 (MTM : 83DK000FUS)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have the same problem on the same device (Lenovo Yoga 7 2in1 14AHP9) on keys z,x,c,v,h,j,k,l and the right half of the number row, and some other keys as well. Pressing the keys hard and repeatedly temporarily makes it work. But then sometimes it registers multiple keys instead of one. I have tried both on my Linux Fedora and Win 11 OS but to no avail. My suspicion is that when I have the laptop on Stand Mode (which I usually have the laptop set up most of the time), the keyboard is resting directly facing down my tabletop which places continuous mechanical pressure on the keycaps and the switches. I haven't tried cleaning the keycaps or reseating the ribbon yet.
Did you have the same probable cause? Were you able to fix it?
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
I had same issue with virtualy same device – keys not registered and then multiple inputs when pressed on Q to P row, alt and control keypress got "stuck". Ocured in Windows 11, Ubuntu and BIOS.
I have reseated ther keyboard ribbon cable and It got fine. Well on second time at least, after first it was in day back and even worse. I have notised that even if fully inserted ther ribbon cable is little bit tilted, so I would expect problem here. You need to remove back cover (little nasty plastic "stud", cover need to by lifted by some force), disconnect and remove battery.
But your problem could be same or one line of keyboard matrix dying. Good luck with that.
这个答案有帮助吗?
得分 1
1条评论:
I just tried cleaning and reconnecting the keyboard cable and unfortunately it didn't fix the issue. I also think it might be the keyboard matrix :(
由完成的 分享
添加一条评论
It looks like a hardware fault. Shut down, clean the keyboard with compressed air, and gently reseat the internal keyboard ribbon (if comfortable opening it). Update BIOS/firmware as a precaution. If the issue persists across both OSes, the keyboard assembly likely needs replacement. As a temporary workaround, use an external USB keyboard.
这个答案有帮助吗?
得分 1
1条评论:
I'll try updating the BIOS. I have been using a onscreen keyboard for the non functional keys but it sucks.
由完成的 分享
添加一条评论
添加你的答案
Angus “Subie_Main” Fisher 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 116
总计 589
