跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Help Identifying How To Fix Charging Port that Fell Off
Hi.
I've been trying to repair my old 3DS, and for the most part this has gone smoothly with minimal issues. The only problem I'm facing immediately is that I'll need to do some soldering to re-affix the charging port. I have zero experience with this and need a hand identifying what steps I should take with my console.
I've tried to get some up-close photos of it, and I can see a little bit of green/yellow missing from the outer soldered point. They appear black up close, and with some further inspection also seemed to have a residue of something, very thin and eggshell-like.
I'm looking at all sorts of guides to try and figure out what to do, but I've yet to come across any that have damage even remotely similar to that on mine. The port itself doesn't look damaged, thankfully, I'm just struggling to tell where to start on fixing it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The two pads in the middle, labelled 1 and 2, are the only ones you really need to worry about, since they're the ones that carry the power in from the cord. Pin 5 looks like it's probably a ground for the connector shell.
Anyway, it looks to me like the pads are in good shape, so I don't think you'll have any trouble with soldering the port back on. Use some flux and solder wick to remove the existing solder from the pads, then clean them well with 90% or higher concentration isopropyl (rubbing) alcohol.
I went through a few videos showing how to replace that port, but the majority of them use a hot air gun to do the soldering. I did find one that shows how to replace the port using a soldering iron, and it has good suggestions on how to clean the pads and reconnect the legs on the port.
How To Repair Nintendo 3DS Charging Port - EASY - YouTube
If you follow the instructions on the video, you shouldn't have any problem getting your 3DS running again. Good luck, and be sure to come back and let us know how it all turns out!
这个答案有帮助吗?
得分 2
3条评论:
Thanks man! I just wanted to make sure it wasn't entirely unrepairable before I give anything a shot to fix it. Since I have no experience with this sort of thing, I was finding it hard to tell (a lot of guides tend to use more technical terms for the process than I can really grasp at my level). Very thankful for the help.
I'll certainly make another post if I run into another issue or the console works perfectly, though. I had to order basically every other part, aside from the motherboard to fix it, so it's basically a waiting game until that all gets here. But I think it'll all be worthwhile to have one of my earliest consoles running like new again.
完成的
Insanely late reply, I'm aware... Was able to reaffix the charging port, but a few other things went wrong with the repairs that made the device nearly unsalvagable. Was lucky to have made backups prior, but yeesh, can't say soldering is something I'm a fan of.
完成的
@abcd998 Yeah, it's something that definitely takes some practice to get down so I don't blame you for not being a fan. Thanks for the update, sorry it didn't work out.
完成的
添加一条评论
添加你的答案
abcd998 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 140
