跳转到主内容
加入维修社区 - 创建账户
太阳能灯、灯笼和手电筒的维修指南与支持。这些设备通常使用搭配充电电池组的 LED 灯,并由小型便携式太阳能板供电。
Y Is it not changing
Whey is it not changing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Generally these devices don't spend a lot on the battery and after hundreds of charge/discharge cycles, the battery fails. That's the most likely reason, but certainly not the only possibility. If it was mine, I'd open it up and check the charging circuit with a voltmeter. If it's producing power in the sunlight, then I'd leave it charging for at least an hour, then cover the solar panel and check the battery voltage to see if it's holding a charge.
Outside of those general ideas, we can't get any more specific without knowing more about your lamp. A manufacturer and model number or even a couple of pictures of the device might help us identify it and see if there's any information about it available online. You can edit your question to add information or pictures. This guide will help if you want to add photos to your question.
Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ledex 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 38
总计 125
