跳转到主内容
加入维修社区 - 创建账户
2024 年 4 月发布的 Rakuten Kobo Libra Colour 电子阅读器的维修和拆卸信息。型号为 N428 或 N428B。
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
yes that is a broken display, it would need to be replaced.
这个答案有帮助吗?
得分 0
2条评论:
Thanks a lot! wish me luck replacing the screen by myself hahaha
由完成的
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
由完成的
添加一条评论
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Kobo Libra Colour (N428) 屏幕更换 and the Kobo Libra Colour (N428B) 屏幕更换 guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Kobo Libra Colour N428 屏幕图片
指南
难度:
中等
45 minutes - 1 hour
Kobo Libra Colour N428B 屏幕图片
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ISDT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 23
总计 182
