跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
MacBook Screen Going Dark
I have a 2008 MacBook Santa Rosa/Penryn model. My screen started to go black on the left half and within 2 to 3 seconds it would go fully dark. If I closed the lid it would standby, then upon opening, it would sometimes flicker on or stay on for a few seconds, only to go black again. Most times now it doesn't even come on, just stays black. After some research, I shined a bright light to confirm that I can still see the image of my screen with a light, so I assumed it was an inverter board/inverter cable problem. I bought the parts, did the install, and once the last screw got put in, bahhhhh problem still there, no difference. Hooking it up to an external monitor works just fine, but I still want to fix the internal display. Any suggestions? Could it be the backlight bulb in the LCD? Mac wanted 300 or so to fix it before they knew the issue, so I have only dropped 50 bucks plus free labor into it so far, so I am willing to repair more if someone can give me some advice as to how to narrow this down to the culprit.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Any time only a portion of the screen is affected, the problem is the screen itself.
Despite popular opinion, inverters almost never go bad, especially in A1181s. I don't know why people persist in claiming the inverter is the problem when there's a bad backlight...I can only conclude that they must not have repaired too many laptops.
这个答案有帮助吗?
得分 1
添加一条评论
Last thing I think that you have left is to try a new LCD. They are anywhere from $75.00 - $100.00 depending on where you buy it from.
Was the LVDS cable and the inverter board known to be good working parts?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brianjayallen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 887
