跳转到主内容
加入维修社区 - 创建账户
MSI Thin 15 B12V 于 2024 年 1 月发布,是一款轻量级游戏笔记本电脑。它配备 15.6 英寸全高清显示屏,拥有 144Hz 刷新率,搭载最高 12 代 Intel® Core™ i7-12650H 处理器和 NVIDIA® GeForce RTX™ 4050 笔记本电脑 GPU。
How to fix a cracked screen
I cracked the screen on my laptop and it still works but a small part of it is black
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If you want to fix this issue, you will need to replace the LCD panel. Here is a replacement part: https://www.newegg.com/lcdbros-msi-thin-...
Ifixit doesn't have a guide for this, but screen replacements are pretty similar across different models/brands of laptops.
You will need to remove the LCD from the screen panel. To do so, gently heat the edges of the screen. Next, run a thin wedge, fingernail, or craft knife along the edge of the screen to pop the clips. You will now have exposed the LCD panel. Remove any screws and clip connectors, and then swap out the old screen. Repete the steps in reverse order. You may need to add a few drops of glue to hold the glass cover in place if the origional clips broke during disassembly.
Let me know if you have any questions!!
这个答案有帮助吗?
得分 0
添加一条评论
If your MSI Thin 15 screen is cracked and showing a black area, the LCD panel is physically damaged and must be replaced. Cracks cannot be repaired — only replaced. First, confirm the exact model (check the sticker underneath). Order a compatible 15.6" panel matching resolution (usually 1920x1080) and refresh rate. Buy from trusted sellers like LaptopScreen.com, eBay (high ratings), or MSI parts distributors. Before replacing, power off, unplug, and disconnect the battery. Carefully remove the bezel, unscrew the panel, and swap the display cable. If unsure, take it to a repair shop to avoid damaging the hinges or connector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 39
总计 335
