跳转到主内容
加入维修社区 - 创建账户
Rakuten Kobo 的 Clara BW(黑白)电子书的维修和拆卸信息,于 2024 年 4 月发布。型号为 N365、N365B 或 P365。
The on/off button
the on/off button broke and now I need to turn the device on/off using a coin. Is there a replacement button available?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Try making one out of hot glue, a bit of plastic or rubber, or 3D printing. To make a button out of glue or plastic, remove the logic board (you won't have to remove the battery as it sits in a cutout). Then trim the new button or add glue as needed until the logic board fits back in neatly.
My hot glue button looks like this:
It sits quite stiff in the button hole and I can use it by pressing it firmly with my thumbnail. Incorporating plastic from a recycled container would probably make the button less stiff if you prefer.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dieter Haes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 57
总计 325
