跳转到主内容
加入维修社区 - 创建账户
大众途观是一款紧凑型跨界 SUV,它拥有时尚的设计、舒适的驾乘体验以及充足的载货空间。
Why is my engine not starting?
Why is the engine not starting ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
此回答最初是针对另一个问题。
Based on your question, I might need a bit more information.
If you can’t turn on your ACC (accessories) which is your lights, gauges, ect., then your battery is probably dead or your alternator is going out (could also be that your battery terminal is corroded or not connected!)
If you can turn on your ACC but the engine won’t crank over, then it might be an engine issue like the spark plugs or coil packs. It could also be that your fuel pump isn’t working, so fuel isn’t getting to the engine. Also, check your fuses! Make sure none are burnt out or missing. Also, make sure your car is in the neutral or park gear select, as it will not allow you to crank over (run the starter) your car otherwise.
A tip, get an OBD2 scanner or go to shop to get your car scanned, as your issue might be shown there. Lemme know if anything I recommended helped!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cary SANTOS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 172
