跳转到主内容
加入维修社区 - 创建账户
基于无线电授时的电池供电时钟
Time changes automatically with buzzing sou6
Why in my digital alarm clock time changes automatically with buzzing sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This clock uses a Radio Time Server to set its time, that's not to say what's offered is correct as the time zone setting and which time service your click is using may not be correctly set. Make sure the offset from GMT is correct for your location and once set the clock is able to hear the radio signal otherwise it will using its own built in time base.
Things to check is the clock near an outside wall, southward is the best direction in the northern hemisphere. Are the walls brick or metal which can block the signal. If you have a hard time with your cellphone that's a good clue.
The buzzing maybe a messed up Alarm speaker. Here's the product page TFA 602511 Alarm Clock
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SUJAYA KUMAR ROUT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 22
总计 146
