跳转到主内容
加入维修社区 - 创建账户
PS5 游戏机于 2020 年 11 月发布,其视觉效果大幅升级,并配备了创新的全新 Dualsense 控制器。太空时代的黑白配色方案与过去的 PlayStation 设计大相径庭。
Ps5 not reading discs
Hi. My ps5 wont read any discs from the beginning but now i wanted to solve the problem. I changed the whole drive but still he’s saying, can’t read the disc because the disc is not clean or something. After changing the drive, still trying to read the disc but also again give the message he can’t read the disc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Did tou transferred your original (from the old drive) PCB to the new drive? This should always be done.
Can your PS5 read blu-ray movies??
How many games did you test?
I would personally replace the laser deck only.
You can follow this: PlayStation 5 Optical Drive Laser Replacement (till step 38).
It’s possible that the replacement drive is faulty too. I would return it and get a refund. Then try a new laser deck.
Please let us know how that goes!
这个答案有帮助吗?
得分 0
4条评论:
I transferred the pcb from the original. It doesn’t read anything. After 2 minutes it says, can’t read disc, clean the disc (something like this).
I tested 2 disc games. It does the same.
Will a hard reset of the software help? Is this something of the software?
完成的
Nope, usually it’s the hardware. I’m afraid your replacement drive is faulty too. I would return thr broken drive and get yourself a new laser deck and try again.
You can try to format it (make a backup first), but most likely this won’t solve it :(…
完成的
Hi. I changed now the laser desk (returned the drive), still same problem. I used the link from the video on youtube. I don’t know what to change now.
完成的
Okay. I'm afraid it's related to the drive it's PCB or motherboard now (this is rare, but possible). Unfortunately, it's not possible to replace the PCB. I would bring it to a local repair shop and let them check... Is that possible?
完成的
添加一条评论
添加你的答案
Kenan Cankaya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 94
