跳转到主内容
加入维修社区 - 创建账户
2015 年 3 月发布的 11 英寸 MacBook Air 更新版采用了第五代 Intel Core i5 和 i7 处理器,性能和电池续航时间均有小幅提升。
Cause of shutdown when sleeping
What would cause this unit to shutdown after around 20 minutes when put to sleep? We haven't changed any battery or sleep mode settings and the battery is a good one. We can close the lid and open it after a few minutes and all is well, but when it is left closed for say 20 minutes the unit is turned off. We tested it with our clean installed SSD and the same happens..... We have reset the SMC, PRAM, run diagnostics & there are no errors being reported, ..... I have been told this was an issue with Monterey & up, but I never encountered this before....I noticed that when it is connected to a charger it didn't shut down after the lid is closed for a longer time. System is on 12.7.6.....baffled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Is there any indication if it shuts down, or just powers off?
What if the lid remains open, and you put it in sleep mode manually?
完成的
@allanbinderup Only when the lid was closed for around 20. minutes, I tried sleeping it manually and it operated normally.....
完成的
添加一条评论
2个答案
Hi, @livfe I gotchu.
提示
Replace the whole logic board and tell us what happens.
这个答案有帮助吗?
得分 0
1条评论:
Errrr.... Maybe, but the idea here is to fix this unit board included....
完成的
添加一条评论
Give this a read Understanding sleep modes on MacBook Air
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 179
