跳转到主内容
加入维修社区 - 创建账户
Apple 的主流 2020 款 iPhone 于 10 月 23 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统,并有五种颜色可选。它是 iPhone 11 的继任者。
iPhone 12 buttons replacement guide
Hi everyone
I replaced the buttons with new ones, there are no gaps, everything is fine, but I'm lost, I can't understand how long the screws are needed…
Everything is fine, but when I tighten the screw to the end, the button is not pressed, although everything is in place
Could you please tell me if I need to buy these screws separately? And are they sold on AliExpress? What length of screws for buttons do I need?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Unfortunately, there aren't many guides out there for button replacements on iPhones. The closest I can come is to point you to the guides for the iPhone X; fortunately, Apple hasn't changed the basic design of the buttons throughout most of its various models, so the principles will be the same.
iPhone X Charging Pad / Volume Button Assembly Replacement - iFixit Repair Guide
You might compare your work to that for the iPhone X; on that one there are four different lengths of screws used so you might try comparing yours with those on the X and see if there's any correspondence there.
Have you done anything with the exterior buttons? Those could also affect whether the internal buttons are working or not. If you didn't remove or disturb them, then you're probably okay, but there is a guide to replacing those as well on the iPhone X. Again, this procedure will be identical to your phone, at least with respect to actually removing and replacing the buttons themselves, although the procedure of how you get to them will be different.
iPhone X Power and Audio Exterior Buttons Replacement - iFixit Repair Guide
I hope this helps; feel free if you have any questions I may be able to answer since I wrote those guides.
iPhone X 无线充电板 / 音量按钮组件图片
指南
iPhone X 无线充电板 / 音量按钮组件更换
难度:
困难
iPhone X 电源和音量外部按钮图片
指南
iPhone X 电源和音量外部按钮更换
难度:
困难
这个答案有帮助吗?
得分 0
1条评论:
@maksimsokurov said, "So the screws in the instructions are the same as those in the iPhone X?"
I'm sorry, but I do not know the answer to that for sure. I suspect they are similar, but I can't guarantee they are the same. Is there a chance you aren't sure the screws were put back in the same place they came from? As you can see, there are different lengths in different positions.
Извините, но я не могу с уверенностью ответить на этот вопрос. Подозреваю, что они похожи, но не могу гарантировать, что они одинаковые. Возможно, вы не уверены, что винты были вкручены обратно на те же места, откуда их выкрутили? Как видите, винты имеют разную длину в разных местах.
由完成的 分享
添加一条评论
添加你的答案
Максим Сокуров 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 50
总计 351
