How do I replace a thermostat?
Where is the thermostat located and how do I replace it?
What is the engine size and which thermostat do you need to replace?
Reason for asking is the 2.5L engine has 2 thermostats whereas the 2.0L engine only has 1.
这个答案有帮助吗?
It's the 2.5L. I believe its the main engine thermostat, since its the one that works with the heater core. I currently don't have heat in the car and was advised that this is most likely the reason.
The video in the blue link above shows a thermostat in the engine block being replaced at 3:26 minutes
@jayeff Thank you. I'll check it out.
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 53
总计 441
