跳转到主内容
加入维修社区 - 创建账户
福特汽车的修理和支持指南。
Hood sensor switch voltage
Hello.. I am trying to install a remote start kit in my grand daughters 2018 Ford Edge. It requires a working hood sensor circuit, I have discovered the voltage at the hood switch is 3 or 4 volts, Do I look for damaged wiring or could it be a bad BCM? Not sure how far into this I can go before I'm over my head.
Any thoughts please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@jerryparnell "Do I look for damaged wiring or could it be a bad BCM?" neither nor. "3 or 4 volts" That is actually the right voltage. It is a low voltage signal circuit coming from the BCM and that voltage is exactly what the BCM will provide. No error on this circuit.
The latch switch uses ground to indicate the hood is open. For a remote starter you most likely will need to find a wire that shows ground only when the hood is closed.
这个答案有帮助吗?
得分 3
1条评论:
Great.. I will look into this. Sounds like a logical solution,
Thank you
完成的
添加一条评论
添加你的答案
Jerry Parnell 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 17
过去 30 天: 17
总计 17
