跳转到主内容
加入维修社区 - 创建账户
于2015年10月26日上市的第四代Surface Pro平板电脑。
surface pro 4 battery replacement
Do all model of Surface pro4 use the same battery because I am not sure if would order a correct one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, all models of the Microsoft Surface Pro 4 use the same battery.
The Surface Pro 4 (model 1724) has a single battery design across all configurations (Core m3, i5, i7; different RAM/storage options).
The battery specs are consistently:
  • 38.2 Wh
  • 5087 mAh
  • 7.5 V
Common part numbers include:
  • G3HTA027H
  • DYNR01
This is confirmed by repair services, iFixit replacement parts, and listings on sites like Amazon and eBay, which all reference the same compatible battery for the entire Surface Pro 4 lineup. You can safely order a replacement battery labeled for "Surface Pro 4" or "model 1724" without worrying about variations between sub-models.
Tips for Replacement
Battery replacement is possible but challenging. It involves heating and removing the glued screen (high risk of breakage), disconnecting components, and carefully handling the strongly adhered battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenny L 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 13
过去 30 天: 62
总计 388
