跳转到主内容
加入维修社区 - 创建账户
采用 USB-C 充电盒的 AirPods Pro 2 提升了防尘性能、加快了充电速度,还可搭配 Apple Vision Pro 使用无损音频功能。此外,该耳机还配备了自适应音频、对话感知以及个性化音量调节功能。
Left side is not working
My airpod got on water and i clean and drain it and it work for a weak but now the left side is not working what shaĺl i do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
It fell down only
由完成的
添加一条评论
7个答案
最有帮助的答案
Unfortunately, there is not much that you can do, AirPods are generally impossible to open and repair without causing damage to the plastic case.
Water damage happens when corrosion from minerals from your water make contact with the circuit boards of your earphones. You may have to throw away your left earphone since the damage has already happened. Sorry for your situation :(
这个答案有帮助吗?
得分 2
添加一条评论
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=Z77mEmP1...
这个答案有帮助吗?
得分 0
添加一条评论
Some time only I used both AirPods but most of time I used only one side AirPods. One day when I used both AirPods that time I realised one of them AirPods it’s not working.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem only my left ear pod is not working also I didn't drop in water
It was kept on a computer desk and will use it once a week, I tried cleaning the ends and charge ends but nothing works, the right side works and charges asusual
这个答案有帮助吗?
得分 0
添加一条评论
No
It fell down only
这个答案有帮助吗?
得分 0
添加一条评论
It fell down
这个答案有帮助吗?
得分 0
添加一条评论
Lift side no working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
saba beyene 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 38
过去 30 天: 80
总计 645
