跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
Turns on, but before anything happens, it turns off
Basicly, my iPhone turned itself off twice in one week, then the other day, it turned off again, but started itself up again, this time it got as far as loading my pin screen ( so I think ) then it instantly powers down, but then starts up again to do the same again...
When it first did this, it had full charge, and was in a loop of doing this, then the battery died, I thought this might fix it, but as soon as it had charged up, it started it's loop again, whenever it is plugged into anything, it repeats this loop, and I am unable to stop the loop.
What's going on? and how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
SOunds like a battery issue. Change the battery and see if that helps.
这个答案有帮助吗?
得分 2
3条评论:
Well, I went to the Apple Geniuses and they fixed it, but now theres a error 9 every time I try and restore it......
完成的
Krys, how did they "Fix" it? Have you tried to put it in DFU mode and restore it again?
Here's how.
INSTRUCTIONS
Step 1. Turn off iPhone
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that it’s in restore mode.
完成的
添加一条评论
添加你的答案
Krys 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 1,086
