跳转到主内容
加入维修社区 - 创建账户
Canon EOS 5D Mark II 是一款 2110 万像素全画幅 CMOS 数字单镜头反光 (DSLR) 相机,具备视频录制功能。
How to fix error 06
self-cleaning sensor unit malfunction
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Error 06indicates a malfunction with the Self-Cleaning Sensor Unit, meaning the automatic sensor cleaning process failed, often due to a stuck sensor or mechanical issue with the cleaning mechanism. Basic troubleshooting involves turning the camera off and on, removing/reinserting the battery, and sometimes gently tapping the camera, but if the error persists, it likely needs servicing by a professional Canon repair center.
Troubleshooting Steps (Try in Order):
  1. Power Cycle: Turn the camera's power switch to OFF, wait a few seconds, then turn it back ON.
  2. Battery Reset: Turn the camera off, remove the battery and memory card, wait a minute, then reinsert them and power on.
  3. Gently Tap: With the camera off, try gently tapping the camera body (not too hard) to potentially dislodge the sensor unit.
  4. Disable Automatic Cleaning: If the camera turns on, try disabling the automatic sensor cleaning in the menu to prevent it from triggering the error.
  5. Check Lens Contacts: While less common for Error 06, ensure lens and camera contacts are clean, as communication issues can sometimes cause general errors.
This video demonstrates the basic troubleshooting steps for a Canon DSLR camera:
这个答案有帮助吗?
得分 0
1条评论:
Note that no official Canon repair center will repair the camera as the service life of the Canon EOS 5D Mark II has ended. Repairs can only be made by third party repair shops.
由完成的 分享
添加一条评论
添加你的答案
Muhammad Syah Levi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 45
总计 501
