跳转到主内容
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
What SSD sled do I need?
My macbook died and I have the SSD with my data. I am trying to buy an enclosure so I can extract the files.
Samsung M.2 NVMe SSD (PCIe), 128 GB, 2280 form factor
I bought two incorrect items already (External M.2 SSD NVMe Enclosure × 1)
What do I need to buy for this specific item?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@margaretwhedon It might help if you let us know what exact Apple 'macbook" this comes out off. Apple used SSD’s that use proprietary connections and are not M.2 compliant!
If anything, check the ones on here as well as this one
这个答案有帮助吗?
得分 2
2条评论:
MacBook Air (13-inch, 2017), Apple Model Number: A1466, Model Identifier: MacBookAir7,2, Serial Number: C02W92BJJ1WK, Purchase Date: April 26, 2018
Thanks for your suggestions! The first one looks exactly like what the folks at Apple used to read it; unfortunately it is sold out. I'll look into the second option!
完成的
@margaretwhedon 2nd option should work for this SSD as well. Best of luck to you and let us know how it works out.
完成的
添加一条评论
添加你的答案
margaret whedon 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 15
过去 30 天: 15
总计 15
