跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,New Nintendo 2DS XL 是 2DS 掌机的技术改进型重塑机型。它是 Nintendo DS 系列的第九款,也是最后一款重新设计的产品。该主机比原始的 2DS 机型大得多,并增加了“New 3DS”系列升级版系统的所有功能,减去了在顶部屏幕上以立体 3D 效果玩游戏的功能。
problems with hinge/spine of 2ds?
so when i try to move the top screen of my new 2ds backwards after repairing and swapping the shell it doesnt close fully on the back and has trouble when i try to put the top screen flat in line with the bottom ive tried opening and cleaning it i also reseated the top lcd
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This usually happens when the hinge isn’t aligned correctly after the shell swap. Even if the screen and LCD are re-seated, the top housing won’t close or sit flat if:
1. The hinge barrel isn’t fully rotated into its locked position.
It needs to “click” into place. If it’s off even a little, the lid will resist closing.
2. The ribbon cable has tension or is twisting inside the hinge tunnel.
A slight twist is enough to keep the top shell from lining up.
3. One of the hinge tabs isn’t sitting in the shell track.
The system will close on one side but not the other.
Quick fix:
Open the system back up, rotate the hinge fully until it locks, check that the ribbon sits smoothly with no sharp bends, and then reassemble.
No new parts needed unless the hinge barrel is cracked.
If you want, I can tell you exactly how to check alignment step-by-step.
这个答案有帮助吗?
得分 0
1条评论:
that would be nice thanks
完成的
添加一条评论
添加你的答案
God o 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 55
总计 540
