跳转到主内容
加入维修社区 - 创建账户
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有 15.4 英寸 LED 背光显示屏,支持 True Tone 原彩显示技术、Touch ID,最高搭载 6 核心酷睿 i9 处理器。
Topcase Replacement Issues - Wont display
Hi all,
I had to replace my top case on my 2018 MacBook Pro 15 inch (A1990). I worked through everything slowly and purposefully. When I tried to turn it on it wouldnt turn on. Then I connected the mains power adaptor and it fired up, I heard the chime but nothing on the display. The Touch Bar lit up and I could increase the volume and decrease but nothing else. Now I cant turn the unit off.
Can anyone shed any light on what might have gone wrong with the procedure or what I need to do to get it up and running again!
Many thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Why did you replace the top case? Do you mean the display lid part or the uppercase keyboard part?
由完成的
It was the keyboard part DanJ
由完成的
@mansoorahm23124 - OK, did you have a liquid spill of some sort?
由完成的
No, some of the keys were missing so thought of replacing the keyboard. Unfortuantely, that meant replacing the topcase in its entirety!
由完成的
添加一条评论
1个答案
I would look at the guides and check that the LCD cable is connected and also the battery connection. IF still no improvement then prehaps @danj can give some more insight.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mansoor Ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 179
