跳转到主内容
加入维修社区 - 创建账户
Lenovo LOQ 15IAX9 搭载英特尔 i5-12450HX 处理器,最高可选 RTX 4060 显卡,配备 15.6 英寸 FHD 144 Hz 显示屏,最高支持 32 GB DDR5 内存、PCIe Gen4 固态硬盘,内置 60 Wh 电池,并拥有包括 HDMI 2.1 和 USB-C 在内的完整接口。
Usb ports not working
Good day I trust you are well. I have the above mentioned laptop. I use a cooling pad as well as accessories for gaming, my two rear usb ports suddenly stopped working. I have gone through the drivers as well as softwares and checked that everything is correct, usbs are still dead. Any advice? Kind regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Dell USB port not working
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @wouterbred35891
Connect a mobile phone or USB mouse to one of the USB ports and check if the phone starts to charge or the mouse's laser light turns on.
If they don't go to Device Manager and check that the USB Power Management setting of "Allow the computer to turn off this device to save power" is unchecked.
To get to Device Manager in Win10/11 press the Win key + x key (both together) and select the Device Manager link in the options menu box that opens.
When in Device Manager scroll down to Universal Serial Bus Controllers → click on > symbol to expand the entry list → right click on a USB Root Hub entry → Properties → Power Management
If the checkbox is checked uncheck it → OK
Do this for all the USB Root Hub entries shown in the list.
When completed, close all open windows and then restart Windows in the normal manner and check if the USB ports now work OK
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wouter Bredenkamp 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 63
总计 586
