跳转到主内容
加入维修社区 - 创建账户
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
Stuck in DFU mode
Laptop had water damage on elc180 that powers nand chips, after repair laptop is stuck in DFU mode and revive option gives error amrestoreerrordomain – 0x6 (6)
Data is the most important part of the repair if i do a restore and delete data from laptop repair is not of anny help.
does someone have a solution that saves data.
All voltages and resistances are fine laptop is only not turning on vcore on cpu and gpu.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The low level aspects of the Flash chips (NAND) are corrupted. Without a DFU restore you really can't get past to save the data, sorry.
As a Hail Mary see if an external drive which is setup as a bootable drive will at least let you boot up. While you likely won't see the internal drives data as it's encrypted by the user account can you even get that far?
这个答案有帮助吗?
得分 0
2条评论:
Hi, do you by anny chance have T2 rom files for A2141 820-01700-05
由完成的 分享
@dimitrijes46692 - The T2 chip is not reprogrammable! It is a gate array chip with a burnable Readable only ROM. The systems firmware is held in a EROM chip, but that won't help you here. That nukes the access to the NAND's like rebuilding via DFU.
由完成的 分享
添加一条评论
添加你的答案
Dimitrije Stefanovic 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 45
总计 573
