跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 手柄的维修指南和相关信息。
Right joycon doesn't connect wirelessly
Hello
my right joycon works only when attached on the switch but does not connect wirelessly when taken off, the switch doesn't even recognize it.
It is not an antenna issue, i've already tried replacing it, its not a switch issue as it works with other joycons, the joycon (that doesn't work) doesn't connect wirelessly to any switch i've tried it.
From reading i suspect it being a problem from the bluetooth chip on the motherboard, any suggestions?
edit: I've tried connecting the right joycon to my phone via bluetooth and it doesn't show up but trying with the left one it does show up
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
In this case it does sound like a issue with the bluetooth chip. So replacing that chip will most likely solve it. Soldering is required for this.
I would just replace the motherboard. You can buy them on Ifixit when it’s in stock. Otherwise you can try AliExpress. They are not that expensive, so it’s worth it in my opinion.
Please let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
took a long time to get the replacement part, but in the end it works now after replacing the motherboard
由完成的
Alright! Good to hear that it is fixed anyway now :)!
Have a great day!
由完成的
添加一条评论
添加你的答案
Astronyu 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 24
过去 30 天: 41
总计 385
