跳转到主内容
加入维修社区 - 创建账户
HP ProBook 640 G4 或 ProBook 640 G4 笔记本电脑是一款于 2018 年夏天首次发布的笔记本电脑,属于第四代 HP ProBook 系列。HP ProBook 640 G4 是一款定价适中的 14 英寸商用笔记本电脑。
Laptop screen is blinking
How to repair laptop screen blinking
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Please try connecting an external monitor to your laptop. If the screen is appearing as normal, it is more likely to be a hardware failure of some kind, that the screen module is broken, loose or damaged cables etc., and the faulty component would need to be repaired or replaced.
If your problem appears on an external monitor too, it is more likely to be a software problem, it can be faulty driver or a GPU problem. Try making sure that you have all your firmware/drivers/BIOS up to date and try making a clean install of your GPU drivers. If your running windows 11 you can on-top of this also go to Settings > Windows Update > Advanced Options > Recovery and then select "Fix problems using Windows Update" by pressing Reinstall now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bharti Aswani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 125
