跳转到主内容
加入维修社区 - 创建账户
于 2023 年 1 月发布,搭载第 13 代 Intel H 系列处理器,可选配 RTX 3050 4GB 显卡。该机采用铝镁合金机身,配备 14.5 英寸 2880x1800 OLED 显示屏,型号为 UX3404。
Flickering screen repair steps
The screen of the laptop is flickering. I was recommended to change the screen. Is it repairable
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
who recommended replacing screen? The flickering can be caused by many problems. Screen replacement would be the last option.
First open a CMD prompt window and run chkdsk c:
Then open a CMD prompt window as admin and run scf /scannow
Then look for the lasted driver for your video system and install that.
Now, if you have a video port on the laptop, try connecting an external monitor. If that doesn't work, it is likely a problem on the MB.
If you got this far without solving the problem and the external monitor worked, open the laptop and disconnect and reconnect the screen cables - search for how to open the connectors and be careful as the are fragile.
If the problem still exists, now you can consider if it is economically feasible to replace the screen or buy a new computer.
这个答案有帮助吗?
得分 0
1条评论:
Micro center’s repair tech recommended replacing the screen. I have tried your suggestion, the problem persist but the computer works with an external screen.
由完成的
添加一条评论
添加你的答案
Babacar Faye 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 52
总计 483
