跳转到主内容
加入维修社区 - 创建账户
Light control are jammed
Cannot turn on the light the controls had jammed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your Grand i10’s light control is likely stuck because of a failed or worn combination switch, though it could also be a blown fuse or a dirty switch mechanism. Try gentle movement + contact cleaner and check the headlamp fuse. If it’s still jammed, the stalk assembly needs replacement — a quick and inexpensive repair at most workshops.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Khorsing Ingti 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 164
