跳转到主内容
加入维修社区 - 创建账户
Light not working properly
Light under door comes on dim periodically by itself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @tee51192
What is the model number of the microwave oven?
由完成的 分享
LMV1825SW model number
由完成的 分享
Sorry having problems navigating. First time user. 93 years old
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Hi @tee51192
It may be that the light timer has been activated. Try cancelling the light timer and check if that resolves the problem.
Scroll down the relevant page from the user manual to find out how to enable and to cancel the light timer
这个答案有帮助吗?
得分 1
添加一条评论
Tee, that light is controlled by a relay on the control bd and is a 110V bulb. Two possibilities: 1. the relay is defective. 2. there is grease build up partially shorting the contacts out. Either way, it should be fixed b4 it causes bigger problems.
Obviously, the first thing to try is replacing the bulb, but for it to come on by itself at low intensity doesn't point to a bulb failure - but anything is possible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 48
总计 245
