跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro 8 维修指南,发布于 2021 年 9 月 22 日。
Surface Kickstand Compatibility Replacement
does anyone know if the surface pro 9 or pro x kickstand is compatible with pro 8?
they seem exactly the same
unfortunately one of the ears of my kickstand is damaged and the problem has been to find anyone having the part or being able to order it, i mean it was released 4 years ago, it shouldn't be that hard to get an hardware part
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
no, the Pro 9’s kickstand isn’t the same part as the Pro 8’s.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @hugoparaschi
The part numbers for the kickstands are different between the 3 models you mentioned so presumably they're not interchangeable.
Here's an image from the Surface Pro 8 parts list showing the part numbers for the kickstands.
Search online for the CRU part number, applicable to the laptop model and colour you need, to find suppliers that suit you best.
(click on image)
这个答案有帮助吗?
得分 1
3条评论:
tks a lot @jayeff, i also notice, after a closer look at the hinge inserts that they differ
do you know if it's feasible to remove the "ear" strap from a new kickstand and glue it back on the old? like i said, my problem is just a defective plastic piece and i can only find the part in dark grey available in the us 😢 on ifixit there's only the silver
由完成的
@hugoparaschi
I don't know.
Also not sure what type of adhesive to use as best that I can find out is that the kickstand is made from a magnesium alloy which might be difficult to join as well.
Here's the guide that has instructions for how to remove/replace the kickstand, if you haven't already seen it
由完成的
appreciated for all your input
the problem isn't replacing it, but finding the part 😭
由完成的
添加一条评论
添加你的答案
Hugo Paraschi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 264
