跳转到主内容
加入维修社区 - 创建账户
Toyota RAV4 在 2006 款车型上进行了重新设计,采用了全新的平台,并首次在 2005 年法兰克福车展上亮相。
Rear window wiper not working
The rear window wiper doesn’t move, it spills water, but doesn’t wipe
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mohammadba94877
Check if the the rear window wiper fuse in the instrument panel fuse box is OK.
The fuse number is different for different variants of the RAV4 e.g. in the EU it is fuse #3, in the USA it is fuse #20, in other areas it is fuse #4.
Consult the owner manual or the fuse layout diagram in the fuse box lid to find which fuse is used in your model.
If the fuse is OK then check if the rear window wiper motor is OK.
Here's video that may help.
If the motor is OK it could be a problem with the multifunction switch on the steering wheel or the wiring from the switch to the wiper motor.
Here's an image from the 2006-2012 RAV4 repair manual, showing the wiring diagram for the rear window wiper.
(click on image)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mohammad Backer Kassir 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 22
总计 200
