跳转到主内容
加入维修社区 - 创建账户
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
PROBLEM with screen image.
Today i had this surprise... the computer is working... if i connect a Hdmi to a tv or monitor.. it works fine.... has energy signal in the LCD but.. doesn´t appers any image in the Monitor ..is this a Flex or Tcon defect .. or i have to replace the intire Screen .. ???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's hard to tell just from the grainy picture. Is the screen lighting up (glowing) if it is the backlight is working so that would remove the backlight flex issue.
Does the screens image change in any way moving the lid up and down or connecting or disconnecting the HDMI connection? If not then I would say the T-CON has an issue or the connecting to it. This is a different cable than the LCD cables which compose the image within the LCD. Do you have any damage within the Chin plate which sits just below the displays image area? That would be the LCD cables being damaged.
And lastly you didn't have a liquid spill or place the system down on a wet surface as the back hing area is quite open and wouldn't take much to get into the T-CON board.
In any case the display assembly would likely need replacing MacBook Pro 16" (2019) Display Assembly and here's the guide 2019年16寸MacBook Pro 屏幕更换
Replace a display compatible with a model A2141 2019 16" MacBook Pro laptop. Includes the 3072 x 1920 LCD screen, display cover, bezel, FaceTime HD Camera, and clutch hinges.图片
产品
$444.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
orlando reis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 65
