跳转到主内容
加入维修社区 - 创建账户
EvoFox Fireblade 游戏键盘标配 Windows 锁定键、12 个多媒体按键和 USB 即插即用功能,其带有呼吸灯效的彩虹背光使键盘始终清晰可见,外观出色。 专为游戏打造——经受住了 1000 万次按键的实战考验,采用防泼溅设计,配备 1.5 米长编织线缆和用于精准数据变速箱的磁环。
Broken Type-C Port
my keyboard's type-c port is broken how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Okay, I couldn't find a good video for you to use nor a part supplier...
SO: Here's what you can do HERE is a video of a fellow doing a tear-down and reassembly of your keyboard, unfortunately he never gives us a look at the actual USB port inside, but that's Okay, you will see what you have when you get it open and the video DOES show you how to open it up and put it back together.
THEN, you have THIS video where a fellow shows how to replace the USB port on a gaming PC which, together, may allow you to do the job.
A side note, if you CAN'T get an appropriate USB port to replace the one you've got, you may be able to replace it by using a USB-C port on it's own PCB, use the wires coming from you board to the port if possible or soldering connections to the board itself to the port, gluing it in place of the old broken one (Half-arsed, yes, but possible if you can't find a better solution. That should let you do the job... maybe you can make a guide for the next guy who finds him/her self in the same boat.
Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Huss Nain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 178
