跳转到主内容
加入维修社区 - 创建账户
Kenmore 110 系列是由 Kenmore 生产的一款易于使用的家用洗衣机。
Need schematic, Cannot find. Code F28
Hello. I need the schematic for a HE2plus Kenmore, model 110.47511701 . I have exhausted my search.
I am getting a code F28 after changing the door latch, the control panel and the inlet switch.
This machine will not start filling.
The drain pump was also replaced recently and worked fine.
The machine was reset numerous times and connections checked. The only thing left is to put a meter on it.
Any help will be appreciated. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Have you checked inside the machine for service sheets that are often stored there for technicians to use?
由完成的 分享
Yes, it is missing.
由完成的 分享
This model is made by Whirlpool.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Hi @rebeccatraub
Here's the tech sheet for the washer.
F28 is a communications error between the Control board and the User Interface.
You didn't specify which connections you checked but recheck the UI board to the Control board connections at both ends. Look for corrosion on the connector pins perhaps.
这个答案有帮助吗?
得分 2
添加一条评论
I'm still looking, but so far the only source I've found is a site called servicemanuals.net that claims to have the manual available for purchase in either digital or paper form for $16.99 or $29.99 respectively. I can't vouch for them, sorry to say, as I have had no experience with that site.
KENMORE 11047511701 110.47511701 Service Manual-Service Manuals
I did run across an eBay listing that said the part they were selling was from a washer with a quote:
Maybe double check any control board plugs that were disconnected or jostled?
这个答案有帮助吗?
得分 1
1条评论:
Thanks. I just ordered the info. Site looks a little sketchy but we will see.
Thanks again.
由完成的 分享
添加一条评论
添加你的答案
RJ Traub 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 28
总计 176
