跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your LG TV.
TV IR Sensor not responding
My LG TV is not responding to signals from my full functioning remote control. Model Number: 42LG3000
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
@kristiansharp you've checked your remote to make sure it does send signals? Your TV functions as usual with the exception of not responding to anything form the remote?
完成的
@oldturkey03
Hi Old Turkey (seems a little unfair! :) )
Yes, I have new batteries, I have new genuine LG remote control which arrived today. it still wouldn't pair with the TV. My TV has been unplugged for over 30 minutes to try to force a hard reset on the TV itself. Nothing works.
完成的
@kristiansharp ;-) have you checked the remote with your cellphone camera to make sure it sends signals. Why did you need to replace it? Can you use your TV without a remote? Does that TV work okay? What model is your remote? I am thinking that this is either the remote or the IR sensor which is part of the power button on the front of your TV. Part number for that is EAX43425703
完成的
Yes, I have checked the remote with the camera on my phone, I can see that works fine.
My original remote was working fine and then stopped working suddenly..
Is the IR Sensor part of the Power Control Circuit Board?
完成的
添加一条评论
1个答案
@kristiansharp the IR board is the part where your power button is. You will have to remove the back cover form your TV (disconnect the power cable of course) then locate the IR board (same location as the power button from the front). Remove and replace the board. Luckily it is readily available at many online stores and really not to expensive. After that, re-evaluate.
Let us know what you find out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristian Sharp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 86
总计 290
