How to fix bent port (to the laptop end).
The cord is bent. Will work in a certain position. Otherwise it will not. Anyway I can fix this?
@kit21649 we really would need to know what power supply this is. If it has a common barrel connector, you can replace that one. I would suggest that when you do replace it, cut the wire a bit longer at the connector end. That way you can be reasonably assured that you eliminate broken wires as well. Let u know what power supply this is and if possible post a couple of pictures of the connector with your question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 16
