跳转到主内容
加入维修社区 - 创建账户
作为最初版 Nokia 8110 的复刻,这款手机于 2018 年发布,也被称为“黑客帝国手机”。
How to update firmware for US use.
My phone was purchased on line. when arrived found out not intended for USA use. Was set up for Vietnam. Changed language in settings but never got good or full support from ATT. Now have Cricket. Would love to start using that great phone again. Can the firmware be changed to something modern and USA/ Cricket supported? Can the battery be replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You can find the battery on Amazon and other places and videos on YouTube for how to do it.
I just spent some time trying to find an answer for you, at first all I found indicated it's probably not an update-able issue, rather the fact that the US carriers no longer support the bands in use by the phone. More digging however led to the conclusion that it still can I found this. It seems to say a number of carriers DO still support the phone.
So, the usual route to make such a phone usable in the US (if necessary) would be to flash the manufacturer's stock ROM for the particular carrier if available, in this case probably AT&T where you could, if they sell the phone, get the appropriate ROM to download. Or from Nokia a stock version for the exact model you have as well as in US English. On XDA and other places I found that yes, there are actually several options to upgrade your OS, should you wish to do so, KaiOS, Android and a couple others. I'd check with your carrier first and see if they have a ROM for the phone and that, yes, whatever you plan to do, will work. Flashing a new OS is not risk-free though so the ball is in your court. It may work as is with a new battery, or you might want to stick a newer or preferred OS in the puppy, I've done that several times and won't discourage you, just be careful, understand every action and have everything you need before you begin... You CAN brick it if something goes wrong.
Good Luck.
这个答案有帮助吗?
得分 0
添加一条评论
It sounds like you're encountering a firmware-update barrier with your setup. A good first step is to check compatibility ensure your device’s region (US in your case) and version matches the firmware you’re trying to install. Next, back up any critical data before proceeding, since firmware updates can erase or corrupt data if interrupted. Also, make sure your network connection is stable and you’re using the correct USB or interface cable (a bad connection often causes failure).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Fagan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 246
