跳转到主内容
加入维修社区 - 创建账户
2019 年 9 月 20 日发布,这款 Apple 的主流 2019 款 iPhone 配备了 6.1 英寸 LCD 触摸屏、双摄像头,并提供六种颜色选择。它是 iPhone XR 的继任者。
How to hard reset iPhone 11
how to hard reset iphone 11
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
how to flash iphone 11
完成的
添加一条评论
2个答案
Hello.This operation will not erase the data.
The procedure is as follows.
Press the volume up button and release it immediately.
Press the volume down button and release it immediately.
Press and hold the side button (power button).
When the Apple logo (apple mark) appears, release your finger.
Matters to be attended to
This procedure is intended to troubleshoot if a normal restart is not possible or if the screen freezes.
If "hard reset" means "initialization" to return the iPhone to its factory state, the operation method is different. After initialization, all content and settings in the iPhone will be erased. If you want to initialize, you need to do it from the "Settings" app or connect it to your computer (Finder or iTunes).
This is the end. From gkps.
这个答案有帮助吗?
得分 0
1条评论:
Light up the flashlight from the control center
Open Control Center: For iPhone 11, tap the upper right corner of the screen and swipe down.
Tap the flashlight icon: Tap the flashlight icon to turn on the light.
Turn off the light: Tap the icon again to turn off the light.
"Turn on" the flash with the camera app
Launch the camera app: Open the "Camera" app from the home screen.
Tap the flash setting icon: Tap the lightning mark displayed at the top left of the screen.
Select "On": Select "On" from "Auto", "On" and "Off".
Setting to light up the flash when receiving incoming calls or notifications
Open Settings: Open Settings and select Accessibility.
Tap "Audio and Visual": Select the "Audio and Visual" item.
Turn on "LED Flash Notification": Turn on "LED Flash Notification".
Set to muting: Turn on/off "Flashing at muting" if necessary.
From gkps.
完成的
添加一条评论
Reset your iphone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oguta Sokya 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 74
过去 30 天: 240
总计 1,540
