跳转到主内容
加入维修社区 - 创建账户
2021 年 10 月发布的 16 英寸 MacBook Pro 的维修指南和拆解信息,配备 Apple 设计的 M1 Pro 和 M1 Max SoC。型号 A2485。
I need this cable
Broke this cable replacing the screen and now the keyboard does not work
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
That is the lid angle sensor cable. What is your exact model (year) as there are a few different versions.
由完成的 分享
Hi and thanks for responding, it is a 2021/2022
Model: A2485 EMC: 3651
Would this cause the keyboard to not work?
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Yes the sensor cable needs to be connected and working. Apple in this series requires the sensor to be calibrated if you change it. Also note a new part will not have the sensors firmware downloaded to it yet so that will require access to Apple's paywall tool by buying the part directly from them (see the lower answer segment)
Getting a used part is the cheaper way and the magnets frame on the lids side can be rotated you should be able to dial in the adjustment by carefully rotating the magnet so the sensor already programmed setting is reused. With the newest macOS you can also review your parts and by pass Apples serialization as they caved on it. Sadly many used parts houses only have the new part presently which depending on your OS level maybe an issue. I haven't tried the onboard recalibration process yet on this series so I can't tell you if it works or not.
Here's the details on the needed part: Lid Angle Sensor 661-23648
To get the part directly from Apple from their Self Service site Apple self-service Repair just go to the #2 option to order it and the Apple official repair manual is here 16" MacBook Pro (2021) repair manual
这个答案有帮助吗?
得分 2
1条评论:
Thank you for the info! I am going to try the used method. F Apple!
由完成的 分享
添加一条评论
添加你的答案
Corey Hardenburg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 276
