跳转到主内容
加入维修社区 - 创建账户
Date time are not
Replacing the cimos battary
And over heating issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What do you mean? Are you asking if you need to replace the CMOS battery or did you and now the date and time are not correct?
What is the date and time showing, and then after you set it and turn the system off and back on is it what you set or back to the wrong one you had just altered it from?
由完成的
添加一条评论
1个答案
An over heating system can be as simple as clogged fan and heatsink so the system can't cool its self. It is also possible the battery is failing and needs replacing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joy Deb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 148
