跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X270 是一款耐用且紧凑的笔记本电脑,专为经常出差的商务人士设计。它具有超长的电池续航时间、强大的性能和出色的可升级性,模块化的设计使其易于维修和保养。
no screen while turning on
when i turn in my laptop it initially turns on with black screen and suddenly automatic turn off with cpu fan
even on charging or battry replacement, ram replacement , direct power supply
The problem remains the same
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @gamerzone39946
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
Disconnect the charger from the laptop. (if connected)
Open the laptop and disconnect the RTC coin cell battery from the motherboard.
Here’s the hardware maintenance manual for the laptop. Go to p.82 (88 of 114 pdf) in the manual to view the procedure to remove/replace the coin cell battery.
When the coin cell battery is out measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old replace it.
Press and hold the laptop’s Power On button for a full 30 seconds and then release it.
Reconnect the RTC coin cell battery, reassemble the laptop in the reverse order to the disassembly procedure, connect the charger to the laptop and try to start it.
If it starts, there may be a message about the date and time being incorrect. This is normal as the above procedure has reset the BIOS back to its factory defaults. Once the date and time have been adjusted, the message won't appear the next time the laptop is started. Any user defined BIOS settings that have been altered by you to suit your particular requirements will need to be changed back also.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gamer Zone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 287
